Bug Filed on 12-24-2015: TSL256 Sensor not added: Failure
Jessie
8gb
pi2
I’m getting the following error when trying to add a TSL256 sensor:
Please fix the following errors:
Failed to add the sensor, please re-check your settings. Make sure you selected the correct Channel/Slave Address.
From the following code I’m assuming I should select 39 as the address? I have 29, 39, and 49 but none of them worked.
pi@raspberrypi:~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – -- – -- – -- – -- – -- – -- –
10: – -- – -- – -- – -- – -- – -- – -- – --
20: – -- – -- – -- – -- – -- – -- – -- – --
30: – -- – -- – -- – -- – 39 – -- – -- – --
40: – -- – -- – -- – -- – -- – -- – -- – --
50: – -- – -- – -- – -- – -- – -- – -- – --
60: – -- – -- – -- – -- – -- – -- – -- – --
70: – -- – -- – -- – --
39 is the correct default address to use for the TSL2561. Weird. Can you post a screen shot of your setup?
Hmm I just tried again and it seemed like the page locked up, I waited about 2 full minutes. Then I refreshed and tried again and it said the sensor was already added, so I went back to the dashboard, and there it was!
