Bug Filed on 12-31-2015: WIFI Adapter Bug
Jessie
8GB
Pi2
Using a WiFi adapter causes some weird dashboard bugs where adding devices and toggling switches sometimes times out/displays and error. @bestes saw this while troubleshooting the other day.
Thanks For reporting this we will look into the issue.
Also using wifi adapter but not getting too many issues
What model adapter were you using?
Hey Adam,
Been testing WiFi, not running into any issues with turning things off. If you can, try again sometime and see if you experience same problems. I’m thinking with all the improvements we’ve made since this post it may help your situation.
