the bug is very bad as i am sending info to the dashboard and the dashboard keeps on disconnecting the device
Device & model you are using Raspberry Pi 3 B
What dashboard am I using? WEB, IOS & ANDRIOD
here is the code as it is for wind speed. i know it is messy but it worked fine till Friday
#Author : Shailendra Singh #
#email-id : srj0408@gamil.com #
#Code to convert number of clicks to wind speed #
#Technique used here is simple #
#Speed = Distance / time #
#now here distance is Pie * r (where r is the radius i.e. from center of anemometer to the center of cup) #
#In this anemometer, one click is caused when one cup of anemometer cover half the circumference, so when #
#that click happen, we measure time taken #
#and divide the pie * r / time taken #
#now when you use this code, please change .25 to the radius and that too in meter. #
import time
import datetime
import RPi.GPIO as GPIO
import cayenne.client
import logging
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(25, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(22, GPIO.IN, pull_up_down=GPIO.PUD_UP)
logging.basicConfig(level=logging.INFO)
logger = logging.getLogger(__name__)
#variable initialisations
count = 0
count_ch1=0
count_ch2=0
count_ch3=0
timestamp = 0
wind_km_float = 0
wind_km_ch1_float = 0
wind_km_ch2_float = 0
wind_km_ch3_float = 0
#timestamp variables
s_time = time.time()
s_ch1_time = time.time()
s_ch2_time = time.time()
s_ch3_time = time.time()
#cayenne authentication info. This should be obtained from the Cayenne Dashboard.
MQTT_USERNAME = "xxxx"
MQTT_PASSWORD = "xxxx"
MQTT_CLIENT_ID = "xxxx"
def on_message(message):
logger.info('started the cayenne MQTT client')
logger.debug('Message received :%s',str(message))
i=0
def mine_callback_function(channel):
global s_time
time_now_in_callback = time.time()
time_diff = time_now_in_callback - s_time
wind_speed = .25 / time_diff
wind_float = "%3.2f"% wind_speed #we are not assuming wind speed to be more than 999 km/hour i.e. 3 digit
#convert wind speed from meter/hour to km/hour
wind_km = float(wind_float) * 3.6
global wind_km_float
wind_km_float = "%3.2f"%wind_km
print "wind speed of channel 0 i.e. Anemometer on PIN23 in meter/hour is : {0} and in km/hour is : {1}".format(wind_float, wind_km_float)
global count
count = count + 1
print "count before the time comparison is {0}".format(count)
wind_km_float = 0
def mine_callback_function_ch1(channel):
global s_ch1_time
time_now_in_callback_ch1 = time.time()
time_diff_ch1 = time_now_in_callback_ch1 - s_ch1_time
wind_speed_ch1 = .25 / time_diff_ch1 #wind speed in meter /second
wind_float_ch1 = "%3.2f"% wind_speed_ch1 #we are not assuming wind speed to be more than 999 km/hour i.e. 3 digit
wind_km_ch1 = float(wind_float_ch1) * 3.6
global wind_km_ch1_float
wind_km_ch1_float = "%3.2f"%wind_km_ch1
print "wind speed of channel1 i.e. Anemometer on PIN24 in meter/hour is : {0} and in km/hour is : {1}".format(wind_float_ch1, wind_km_ch1_float)
global count_ch1
count_ch1 = count_ch1 + 1
print "count before the time comparison is {0}".format(count_ch1)
def mine_callback_function_ch2(channel):
global s_ch2_time
time_now_in_callback_ch2 = time.time()
time_diff_ch2 = time_now_in_callback_ch2 - s_ch2_time
wind_speed_ch2 = .25 / time_diff_ch2
wind_float_ch2 = "%3.2f"% wind_speed_ch2
wind_km_ch2 = float(wind_float_ch2) * 3.6
global wind_km_ch2_float
wind_km_ch2_float = "%3.2f"%wind_km_ch2
print "wind speed of channel2 i.e. Anemometer on PIN25 in meter/hour is : {0} and in km/hour is : {1}".format(wind_float_ch2, wind_km_ch2_float)
global count_ch2
count_ch2 = count_ch2 + 1
print "count before the time comparison is {0}".format(count_ch2)
def mine_callback_function_ch3(channel):
global s_ch3_time
time_now_in_callback_ch3 = time.time()
time_diff_ch3 = time_now_in_callback_ch3 - s_ch3_time
wind_speed_ch3 = .25 / time_diff_ch3
wind_float_ch3 = "%3.2f"% wind_speed_ch3
wind_km_ch3 = float(wind_float_ch3) * 3.6
global wind_km_ch3_float
wind_km_ch3_float = "%3.2f"%wind_km_ch3
print "wind speed of channel3 i.e. Anemometer on PIN22 in meter/hour is : {0} and in km/hour is : {1}".format(wind_float_ch3, wind_km_ch3_float)
global count_ch3
count_ch3 = count_ch3 + 1
print "count before the time comparison is {0}".format(count_ch3)
GPIO.add_event_detect(23, GPIO.FALLING, callback=mine_callback_function, bouncetime=200)
GPIO.add_event_detect(24, GPIO.FALLING, callback=mine_callback_function_ch1, bouncetime=200)
GPIO.add_event_detect(25, GPIO.FALLING, callback=mine_callback_function_ch2, bouncetime=200)
GPIO.add_event_detect(22, GPIO.FALLING, callback=mine_callback_function_ch3, bouncetime=200)
def main():
try:
while True:
client.loop()
global timestamp
print wind_km_ch3_float
client.windspeedWrite(1, wind_km_float)
client.windspeedch1Write(2, wind_km_ch1_float)
client.windspeedch2Write(3, wind_km_ch2_float)
#print "windspeed of channel 3 is {0}".format(wind_km_ch3_float)
client.windspeedch3Write(4, wind_km_ch3_float)
timestamp = time.time()
except KeyboardInterrupt:
GPIO.cleanup(23)
GPIO.cleanup(24)
GPIO.cleanup(25)
GPIO.cleanup(22)
GPIO.cleanup()
if __name__ == "__main__":
main()
