Can a Cayenne Button attached to a Virtual Pin be turned ON/OFF using code within the sketch?
In my Arduino project, I have three buttons, all connected with Virtual Pins (V1, V2, and V3). This is all working in the sense that I can turn the buttons on and off from within Cayenne and my code is working.
But I still have one problem. I have not seen a way using code in the Arduino sketch to change the state of any of the Virtual Pins and/or the buttons writing to them. What I need to do is turn off a button that’s currently in the ON state using code.
My initial assumption about V1, V2, and V3 was that they were Boolean values - but that wasn’t correct. No matter what is going on within V1, the value of V1==1. Similarly V2==2 and V3==3. And that’s always true, apparently.
What I need is to find out if it’s possible to have two-way communications between the code in the sketch and the buttons in the Cayenne interface.
Is there code I can write to turn off a button displayed in Cayenne?
Here’s my code:
Cayenne valves
#include <CayenneEthernet.h>
int IRR = 0;
int RO = 0;
int LAKE = 0;
int IRR_LED1=2;
int RO_LED2=3;
int LAKE_LED3=4;
char token[] = “xxxxxxxxxx”;
Cayenne.begin(token);
pinMode(IRR_LED1, OUTPUT);
pinMode(RO_LED2, OUTPUT);
pinMode(LAKE_LED3, OUTPUT);
// VOID LOOP
CAYENNE_IN(V1)
if (currentValue == 1)
IRR=1;
LAKE = 0;
digitalWrite(IRR_LED1, HIGH);
digitalWrite(LAKE_LED3, LOW);
Serial.print(“IRR=”);
Serial.print(IRR);
Serial.print(" LAKE=");
Serial.print(LAKE);
Serial.print(" V1=");
Serial.print(V1);
Serial.print(" “);
else
IRR = 0;
digitalWrite(IRR_LED1, LOW);
Serial.print(IRR);
Serial.print(” LAKE=");
Serial.print(LAKE);
Serial.print(V1);
Serial.print(" ");
CAYENNE_IN(V2)
RO=1;
LAKE = 0;
digitalWrite(RO_LED2, HIGH);
Serial.print(“RO=”);
Serial.print(RO);
Serial.print(LAKE);
Serial.print(" V2=");
Serial.print(V2);
Serial.print(" “);
else
RO = 0;
digitalWrite(RO_LED2, LOW);
Serial.print(RO);
Serial.print(LAKE);
Serial.print(V2);
Serial.print(" ");
CAYENNE_IN(V3)
if (currentValue == 1){
LAKE=1;
IRR = 0;
RO = 0;
digitalWrite(LAKE_LED3, HIGH);
Serial.print(LAKE);
Serial.print(IRR);
Serial.print(RO);
Serial.print(" V3=");
Serial.print(V3);
Serial.print(" “);
else
LAKE = 0;
Serial.print(“LAKE=”);
Serial.print(LAKE);
Serial.print(” IRR=");
Serial.print(IRR);
Serial.print(" RO=");
Serial.print(RO);
Serial.print(V3);
Serial.print(" ");
You can change the status of the button by:
Cayenne.virtualWrite(V1,HIGH);
or
Cayenne.virtualWrite(V1,LOW);`
That did the trick. Thank you!!
For reference to hopefully assist anyone else trying to tackle a similar project, here’s my final code (note: you need three Cayenne buttons addressed V1, V2, and V3):
Cayenne valves
int IRR = 0;
int RO = 0;
int LAKE = 0;
int IRR_LED1=2;
int RO_LED2=3;
int LAKE_LED3=4;
int IRR_RELAY1=6;
int RO_RELAY2=7;
int LAKE_RELAY3=8;
char token[] = “xxxxxxxx”;
pinMode(IRR_RELAY1, OUTPUT);
pinMode(RO_RELAY2, OUTPUT);
pinMode(LAKE_RELAY3, OUTPUT);
// VOID LOOP
CAYENNE_IN(V1)
IRR=1;
LAKE = 0;
Cayenne.virtualWrite(V3,LOW);
digitalWrite(IRR_RELAY1, HIGH);
digitalWrite(LAKE_RELAY3, LOW);
Serial.print(" IRR=");
Serial.print(IRR);
Serial.print(LAKE);
Serial.println(" “);
else
IRR = 0;
digitalWrite(IRR_RELAY1, LOW);
Serial.print(IRR);
Serial.print(LAKE);
Serial.println(" ");
CAYENNE_IN(V2)
RO=1;
LAKE = 0;
digitalWrite(RO_RELAY2, HIGH);
Serial.print(RO);
Serial.print(LAKE);
else
RO = 0;
digitalWrite(RO_RELAY2, LOW);
Serial.print(” RO=");
Serial.print(RO);
Serial.print(LAKE);
CAYENNE_IN(V3)
LAKE=1;
IRR = 0;
RO = 0;
digitalWrite(LAKE_RELAY3, HIGH);
Cayenne.virtualWrite(V2,LOW);
Serial.print(LAKE);
Serial.print(IRR);
Serial.print(RO);
else
LAKE = 0;
Serial.print(LAKE);
Serial.print(IRR);
Serial.print(RO);
Making the rest of the Arduino code aware of Outputs turned on by Cayenne
