Can I connect more than one Arduino to Cayenne?
hello community !
Can I connect more than one Arduino to Cayenne via Wi Fi (ESP8266)?
At this moment I have an Arduino connected and running through WI FI but I want to add another one, is that possible?
@ricardo_ramos.l it is possible to add more than one device to cayenne. go to: add new > devices > micro-controller and follow the steps.
Yes, but note if you are using the default Cayenne method, there is a known issue where your dashboard starts to bog down when you reach about 20 devices.
If you go with MQTT and Bring Your Own Devices though, it doesn’t seem to be an issue.
