Can not add sensor at trigger
    Arduino Mega R3 with usb serial connection
    Web
    Please Help…I’m newbie for cayenne world, i want to add some trigger for my sensors, after dragging my device at “if” box, only “State Online/Offline” that appears on the menu option.
    No sensor list at trigger option, all sensor working fine
because all the widgets in your device are actuators and not sensor.
I’m using digital motion sensor, the only actuator in my device is relay switch.
can you share the code and dashboard screenshot .
I’m using code from cayenne sketch file
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 3
#define DHTTYPE DHT22
#define VIRTUAL_CHANNEL 4
#define VIRTUAL_CHANNEL1 3
#define ACTUATOR_PIN 5
#define SENSOR_PIN 4
DHT_Unified dht (DHTPIN, DHTTYPE);
char username = “c0dfc5c0-4770-11e8-8927-a713813a39dc”;
char password = “4f2757dd88577c48c133cc80231ac94498e0e148”;
char clientID = “3b3e27a0-5741-11e8-86cb-01fd27f5d39c”;
//Baud rate can be specified by calling Cayenne.begin(username, password, clientID, 9600);
dht.begin();
sensor_t sensor;
checkSensor();
int previousState = -1;
int currentState = -1;
void checkSensor()
// Check sensor data every 150 milliseconds
if (currentMillis - previousMillis >= 150) {
currentState = digitalRead(SENSOR_PIN);
Cayenne.virtualWrite(VIRTUAL_CHANNEL, currentState);
previousState = currentState;
CAYENNE_OUT_DEFAULT()
sensors_event_t event;
dht.temperature().getEvent(&event);
Cayenne.celsiusWrite(1, event.temperature);
dht.humidity().getEvent(&event);
Cayenne.virtualWrite(2, event.relative_humidity, “rel_hum”, “p”);
CAYENNE_IN(VIRTUAL_CHANNEL1)
if (getValue.asInt() == 0) {
digitalWrite(ACTUATOR_PIN, HIGH);
else {
digitalWrite(ACTUATOR_PIN, LOW);
Hi @saga7o.susanto,
Small bug on our end, we’ll be pushing a hotfix very shortly today.
thank you, I appreciate it :smiley:
okay, already fix, now both actuator and sensor are available at trigger option :smiley:
thanks guys for helping me…
cheers :beer:
