Can not set up triggers! wont drag and drop arduino to" IF" box HELP!
Hi there @convertiblehaus,
What browser are you using? Also, you need to first drag the actual Arduino device over to the IF / THEN statement, not the sensor itself. Does that make sense?
using web dash arduino mega and 5100 sheild
yes it does… im dragging arduino not relay browser is explorer
i installed fresh ide and dash still wont drag… dam
I got it thanks
Glad to hear it!
