Can not start myDevices service
Android and Web
What OS? (Jessie, Wheezy)
Jessie
What Model Pi?
Raspberry Pi 3 Model B
I can not start myDevice service. I found this error in /var/log/myDevices.log
2016-06-09 22:33:18 - myDevices - ERROR - libguththila.so.0: cannot open shared object file: No such file or directory
File “/usr/local/lib/python3.4/dist-packages/myDevices-0.1.19517-py3.4.egg/myDevices/main.py”, line 125, in
main(argv)
File “/usr/local/lib/python3.4/dist-packages/myDevices-0.1.19517-py3.4.egg/myDevices/main.py”, line 121, in main
client = CloudServerClient(HOST, PORT)
File “/usr/local/lib/python3.4/dist-packages/myDevices-0.1.19517-py3.4.egg/myDevices/cloud/client.py”, line 317, in init
self.libMYOPX=CDLL(“/etc/myDevices/libs/libMYOPX.so”)
File “/usr/lib/python3.4/ctypes/init.py”, line 351, in init
self._handle = _dlopen(self._name, mode)
OSError: libguththila.so.0: cannot open shared object file: No such file or directory
Are you running Jessie lite? looks like you are missing some Python modules.
I installed by using NOOBS, then choose jessie on the installation screen.
Install Jessie only. Without noobs ant not Jessie Light.
Any update here? Were you able to install Cayenne?
I’m not sure about this error. I change my sd card, use jessie and then it’s work normally.
Great to hear!
