Device & model: ARDUINO UNO + Ethernet W5100
What dashboard are you using? Trying to connect my Arduino to the Cayenne Cloud using the Web.
I have connection to the internet, I have already run a WebChecker Sketch on the Arduino and a Ping to www.google.com got success.
I am also able to run a webserver in local and light a Led by a web page.
What I cannot is to connect my arduino to Cayenne.
I am using the “Manual Sketch” were I have put the MAC and the IP properly, I reckon.
There is a WAINTING all the time lighting in the screen.
I have checked the Serial Monitor and it is blank all the time. So info on it.
Has someone the same problem??
Thank you very much
#include <SPI.h>
#include <Ethernet.h>
#include <CayenneEthernet.h> // Comment this out if you uncomment a different Ethernet device below.
//#include <CayenneEthernetW5500.h> // Uncomment this and comment out CayenneEthernet.h to use an Ethernet 2 shield or other Ethernet W5500 shield.
_ // You will need the Ethernet2 library installed. See the ArduinoEthernetW5500 example sketch for more info._
//#include <CayenneEthernetW5200.h> // Uncomment this and comment out CayenneEthernet.h to use an Ethernet W5200 shield.
_ // You will need the EthernetW5200 library installed. See the ArduinoEthernetW5200 example sketch for more info._
char token[] = “200fc1hyjs”;
// Mac address should be different for each device in your LAN
byte arduino_mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02};
IPAddress arduino_ip(10, 123, 24, 240);
IPAddress dns_ip(10, 123, 24, 252);
IPAddress gateway_ip(10, 123, 24, 252);
IPAddress subnet_mask(255, 255, 255, 0);
_ Serial.begin(9600);_
_ Cayenne.begin(token, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);_
_ Cayenne.run();_
