Can t make two relays work
not sure how to load second relay is it on the same arduino file or new one
if I load second relay on new arduino file , only one relay works at a time if I load on same page as first relay error code when loading not sure how to add files
That confused me, too. You don’t need to upload a new sketch each time you add a sensor or actuator. Just choose “Step 2: Add widget”.
You should ONLY need to upload 1 sketch, and only at the very beginning. After that, just add widgets, and skip the “upload sketch”, step 1. :wink:
That “step 1” should be removed. It’s confusing.
thank you bin a long weekend lol your a good man!
