Cannot connect to my rasberry to
  • Device & model you are using
    Pi 2 Model B
  • What dashboard are you using?
    Android
First time I’m trying to connect to my rasberry pi with android app. I’m getting the “incorrect ssh user/password or port” error. I’ve seen this error on the forum but couldn’t find the answer. Bellow the screenshot.
Obviously, I tried to connect with connectbot to test the connection and it’s working.
Any help will be very appreciated.
Thanks :slight_smile:
Hi @adrien.stadler
Did you change the username and password on your Pi from the original pi/raspberry credentials?
