Cannot create trigger
Web
What OS? (Jessie, Wheezy)
Jessie
What Model Pi?
B
I have temperature sensor set up. When i go to “create new trigger” I can set name of trigger, type of notification but i cannot set device in “if” section. I tried drag and drop from left hand side menu. While dragging item only name textbox changes its colour to grey.
Im using chrome Version 52.0.2743.116 (64-bit) on MacOs El Capitan.
Are you always stuck under the setup notification? Or are you clicking on it for some reason in particular? Cancel your trigger, start a new one, and you should be able to drop your device (in your case the pi) in first (in the “if”), then select your sensor from the drop down.
@karol.sendyka
Can I ask if you’re trying to drag the top-level ‘Raspberry Pi’ item into the ‘if’ box, or one of the items beneath it? If you drag the top-level ‘Raspberry Pi’, it should pop into the if box and then provide a list of everything under that device that can be used for sensors.
@usmcwarmachine @rsiegel It works! Thank you. I was trying to use particular sensor instead of raspberry pi device. By the way: its not obvious what I should put there and I’m able to drag and drop both items. Maybe its worth considering UX improvement here.
Yeah playing with it a bit I agree, I’m going to see if we already have something on the UX here internally and add it if not.
Right on!
