Can't add relay switch [helped: had previous WebIOPi version]
Select channel is grayed out when I add a relay switch. Any idea what might be the problem?
Thanks,
Martin
Fixed.
I had a previous version installed of webiopi. Had to remove all folders mentioning the previous installed version. Did a reinstall and can pick up the gpio pins now.
Welcome to Cayenne!
Thanks for posting your fix. I moved this to the helped category.
I’ve actually got the exact same issue, except I don’t have webiopi installed and don’t think I have ever. Everything else seems to work - CPU, memory, etc, but not GPIO. I am running pigpio on this unit, is there a known issue with that?
Is there a way to check the daemon running, logs, etc to see what’s wrong?
