Can't add tsl2561
    Rpi 3
    Web and iOS
Cannot add tsl2561 on the web browser even tho I have followed the tutorial to the letter. I get the message to be sure I have selected the correct slave address. The sensor is not addressed so according to your tutorial 0x39 is the default setting. None of the 3 addresses work. I can however add on iOS but that fails to all outward appearances but the sensor shows up on web but does not function.
I have noticed differences in analog readings between web and iOS. 3.3volts on web and 1 volt on iOS. Could it be that iOS is just not syncing up properly?
Try running this command: sudo i2cdetect -y 1
You should see output similar to the screen shot here (but instead of 77 you will see your actual address): https://learn.adafruit.com/using-the-bmp085-with-raspberry-pi/configuring-the-pi-for-i2c
If you don’t get anything showing up there double check your wiring.
