Cant connect arduino to cayenne newbi
hello
first of all i have to apologize for my bad english.i am from germany but i will do my best.
I have problems to connect my arduino uno board with a ethernet shield w5100 connected to my fritzbox.
i am getting the error “view does not name a type” i have already connected my raspberry to cyenne with no problems.
maby someone can help me.
greetings
udo
Can you post your sketch for us to review?
Agreed that the sketch will help a lot to confirm this, but it’s likely an issue with the directory structure of a non-Cayenne library being included somewhere. See this post from StackOverflow: http://stackoverflow.com/questions/18635465/arduino-error-does-not-name-a-type
helle adam thanks for the fast answer. after several trials i have now a different error i will try to copy my sketch.
Cayenne Ethernet Example
This sketch connects to the Cayenne server using an Arduino Ethernet Shield W5100
Steps:
#include <CayenneEthernet.h>
char token[] = "xxxxxxxxxx";
  Cayenne.begin(token);
}void setup() {
i hope thats what you need,
the error reads as followd:
exit status 1
redefinition of void setup
greetings
udo
This is because you have two setup() and loop() functions in your sketch, and there should only be one of each.
If you eliminate the bottom set the sketch should compile. Please note I’ve hidden your Cayenne token so no one reading the forum tries to add a device to your account:
Steps:
char token[] = "yourtoken";
Hello Adam
thank you very much. Now it is running perfekt. and thanks for hiding my cayenne token. I did not think of that.
you are the best!!
greetings
udo
