I realize this is off topic but I need help with my pi.
Rpi2 mod B
latest jessy os
If anyone has a clue as to why my Pi has suddenly gotten stuck in a login loop as in , login is accepted appears to be going to the desktop the loops back to the login screen. i even tried the wrong user/pw and it says incorrect so it appears to accept the 2 users and pw satisfactorily. I change the pw in terminal following instructions at Rpi.org.
I also tried installing on a brand new sd card from samsung. windows kept saying problem with sd card but drag and drop worked fine and then on boot-up I get the raspberry screen and a message saying āwaiting sd card(partitions setting)ā left it that way for hours and the message never stops.
so now I have gotten a fresh sd card install and installed rp_05859s64yl.sh tempurature sensors read but labels are missing. I checked the mac address against the ip address and that show up in the dhcp list in the router. but, my buttons no longer worked on ios, tried restarting ios device and now cayenne app canāt find the Rpi. On the web browser the button have alerts on each āunreachableā and all analog inputs reading 0 now even tho 3.3v is present. cpu temp magically re-appeared.
Furthermore the buttons, extensions and analog input graph are missing.
On the web side, does Cayenne even see the Pi as online? Iām thinking with the reflash/reinstall we may have assigned a different unique identifier to the Pi, not realizing it was the same device.
If thatās the case, it may be easiest to just remove the device from the web dashboard by clicking the settings gear in the upper right, then Configure > Remove device. Once removed, you can re-add it via either the command line options or the iOS app (presuming the iOS app can see the device when you search by IP)
Just followed your recommendation and I got back on track. I have lost the buttons but those were easy enough just have to go associate them with the triggers again and thereās bunch of them.
Hah, yes, they are ā1 wireā sensors that allow us the ability to detect them and create the widgets automatically (so long as they are wired to GPIO 4 on the Pi). Wouldnāt it be nice if all the sensors worked that way?
