Cant select Device when trying to add PCA9685
Hi
I want to add a PCA9685 to my Cayenne dashboard using Raspbarry Pi.
I connected it following the tutorial, but when I try to add it I can’t chose the Pi
does anybody know what to do?
Thank you all
Extension boards are currently not supported with Pi agent 2.0. Have a look at this Raspberry Pi Agent 2.0
Thank you for your answer. Just to get i right, I can’t add it just by wiring and drag and drop?
Sorry for the question I’m just starting…
yes you are right. you can use cayenne MQTT python library https://github.com/myDevicesIoT/Cayenne-MQTT-Python and control the PCA9685 using it .
Ok I’ll try. Thank you
Hi I tried to fix it with python on my raspberry, but with the code i get back following error:
SyntaxError multiple statements found while compiling a single statement.
I Added the correct
MQTT_USERNAME = “MQTT_USERNAME”
MQTT_PASSWORD = “MQTT_PASSWORD”
MQTT_CLIENT_ID = “MQTT_CLIENT_ID”
What am I doing wrong?
can you post the entire error output.
Do I have to add the code in GITHUB to the console or to Python?
follow the installation guide from the github. Once done with install navigate to examples folder and edit Example-03-CayenneClient.py using nano. Add your MQTT credential save and run it .
