Can't SSH into Pi anymore
Web
What OS? (Jessie, Wheezy)
Jessie
What Model Pi?
B
I did a fresh install of Jessie full version. Then I setup a key based password less ssh signing in. Tested and found it to be working. This is when I installed Cyenne. It completed its installation and rebooted the pi. I am able to ping the pi, I can see dashboard from the web client but but I am not able to login using ssh. Connection reset by 192.168.X.XXX (changed IP).
SinceI have not made any changes to the system, I thought it might be helpful for you to investigate and find the root cause of this problem and see if it is related to your software. Otherwise, I am fine doing a fresh install, thats not a problem.
hmmm. I’ve not seen this come up before. I would say just do a fresh install of latest version of Jessie. If this comes up again, then we’ll have to investigate. We change passwords many times and continue to SSH on multiple Pi’s, so I know it’s been done before.
Anyway, thanks for posting this, it’s helpful to track these things. See you around :slight_smile:
Moving this to the Helped category until it comes up again.
I was wondering if there’s some “secret sauce” from the original poster for getting SSH to work after install (I used ssh to install it in the first place).
I’m using:
  • Raspberry Pi 3 Model B
  • Raspbian Jessie Lite 2016-09-23
I guess I’ll just try again with Jessie Full. Huge bummer…
UPDATE: Everything went OK with a clean install of Jessie Full 2016-09-23. I think I had some custom avahi services running before, which might explain it. I dunno, I haven’t tried reproducing the original issue.
Thanks for updating us! Good to know for other who follow along this post :slight_smile:
Hey,
I am also not able to connect and have my pi setup for password less authentication and use an authorized_keys file (as all IoT devices should be). Is there a way to load and protect my private key? Something like JuiceSSH?
Thanks,
