Cayenne and plc siemens s7
Hello everyone can cayenne read data on plc siemens series 300
For example temperatures or pressure value and see this
In Dashboard
You could, but you would need to get the data out to some other device first. I’m not aware if the Seimens S7 can run custom code.
Best is if you could send a data stream out a serial port. An Arduino could then pick that up and format for ingestion by Cayenne.
