Cayenne android app hangs, esp8266 arduino mqtt
    ESP8266 NODEMCU
    ANDROID
    “unfortunately, cayenne has stopped.”
i am using the above for a simple light control. ESP8266 based nodemcu.
I am using the Arduino for the code.
Previously wasn’t using mqtt, until today, had to change over to mqtt .
after changing over to mqtt codes, the devices (2) i can control them through the web, but when I use android app, the two devices is shown as offline.
when I click on the button, it shows the “unfortunately, cayenne has stopped” screen.
I’ve uninstalled and reinstall the app, no difference.
2nd problem … scheduling, i cant add the mqtt button to scheduling ???
some help or pointers please ?
tq in advance.
thank you for reporting this.
currently you have to schedule from the web dashboard only.
I’ve some how fixed it.
I deleted the original button, and add a new button.
so far it seems to be good.
even android app doesnt show the problem anymore
the team has fixed some of the bugs. thank you.
