Cayenne.begin(token); PROBLEM
Good morning, I was using this code in the morning, it was WORKING exacly, then I went out and when I came back, it wasn’t working anymore, I reinstalled the IDE, Libraries, re-upload the code and rebooted the computer… I add this Serial.println to see if the code was looping, but it doesn’t, the code stops exacly in “Cayenne.begin(token);” if I comment this line, the code works normally and start looping (but the cayenne doesn’t works)… I wanna know what’s going on? Why it stopped working… What should I’ve to do?
include UIPEthernet.h // (ETHERNET)
include BlynkSimpleUIPEthernet.h // (ETHERNET)
define CAYENNE_PRINT Serial // Comment this out to disable prints and save space
include CayenneEthernet.h
char token[] = “AuthenticationToken”;
Serial.println(“C”);
I would recommend to delete the device and then add it using new Token.
Which ethernet shield are you using?
I’m using ENC28J60
Hello, maybe you already try but, can you delete the device and add new with token.
