Cayenne dashboard freeze
Hi all
First I’m not write good English or code expert :pensive:
I have little project where is
1 -> Raspberry pi 3 (control arduino and it’s connected lan) and there is Jessie OS
1 -> Arduino Uno (control my sensor etc… connected to Rpi3 with usb-cable)
1 -> USB hub (connected Uno and Rpi3)
6 -> d18s20 temp sensors
2 -> Relays (control water pump and fan)
4 -> Moisture sensors
2 -> water level sensors
Relays, water level sensors and moisture sensors are controlled by Cayenne dashboard. Only code what I have done is temperature sensor code and uptime (see below). Problem is that Cayenne dashboard freezing (after about 1- 10min) when I run cayenne-ser.sh script. Also arduino are freezing and last online status continue running without no control. I have change usb-cables, internet connections, reinstalled Rpi3, arduino codes… etc… I can’t trust that everything works well when I leave my greenhouse. I can do arduino code where everything this works (without cayenne and everything this) but this cayenne dashboard etc… is so good :sunglasses: mobile control etc… I like
if I add more code to my arduino, cayenne dashboard goes online but freeze immediately. If I run only temp sensors code all works fine. Same situation is all other sensors if I run sensors one by one. Everything works fine if I run one by one but if I add evrything in the same code dashboard will freeze. Maybe Uno can’t handle so many sensors but if look forum there is much more difficult system and one arduino :smile: I don’t understand what is wrong. Sorry this code are not full english but I think you can handle that.
#include <CayenneSerial.h>
#include <OneWire.h>
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
#define VIRTUAL_PIN3 V3
#define VIRTUAL_PIN4 V4
#define VIRTUAL_PIN5 V5
#define VIRTUAL_PIN6 V6
#define VIRTUAL_PIN13 V13
const int tmpPin1 = 3;
OneWire oneWire1(tmpPin1);
OneWire oneWire2(tmpPin1);
OneWire oneWire3(tmpPin1);
OneWire oneWire4(tmpPin1);
OneWire oneWire5(tmpPin1);
OneWire oneWire6(tmpPin1);
DallasTemperature sensors1(&oneWire1);
DallasTemperature sensors2(&oneWire2);
DallasTemperature sensors3(&oneWire3);
DallasTemperature sensors4(&oneWire4);
DallasTemperature sensors6(&oneWire6);
char token[] = "xxxxxx";
  Cayenne.begin(token);
  sensors1.begin();
  sensors2.begin();
  sensors3.begin();
  sensors4.begin();
  sensors5.begin();
  sensors6.begin();
//lämpötila-anturit
CAYENNE_OUT(VIRTUAL_PIN1)
sensors1.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN1, sensors1.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_PIN2)
sensors2.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN2, sensors2.getTempCByIndex(1));
CAYENNE_OUT(VIRTUAL_PIN3)
sensors3.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN3, sensors3.getTempCByIndex(2));
CAYENNE_OUT(VIRTUAL_PIN4)
sensors4.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN4, sensors4.getTempCByIndex(3));
CAYENNE_OUT(VIRTUAL_PIN5)
Cayenne.celsiusWrite(VIRTUAL_PIN5, sensors5.getTempCByIndex(4));
CAYENNE_OUT(VIRTUAL_PIN6)
sensors6.requestTemperatures();
Cayenne.celsiusWrite(VIRTUAL_PIN6, sensors6.getTempCByIndex(5));
//uptime
CAYENNE_OUT(VIRTUAL_PIN13)
  CAYENNE_LOG("Data requested for Virtual Pin %d", VIRTUAL_PIN13);
  Cayenne.virtualWrite(VIRTUAL_PIN13, millis() / 60000);
BR -MH
The beginning of the code was left out
#include CayenneSerial.h
#include OneWire.h
#include DallasTemperature.h
  • BR MH
Hi @mattiheikkinen84,
It seems like a really cool project! And your English is very good :slight_smile:
Hmmm. What do you mean by dashboard freeze? The data is not coming into the widgets?
Hi @bestes,
Thanks. Yes data is not coming into the widgets. There is another chain here too…
http://community.mydevices.com/t/dashboard-updates-slowly-or-not-at-all/3600/4
and I will test now this…(what @adam says) -> you cant use the serial output to display messages in the serial console That maybe problem in my code.
-MH
