Cayenne Docs
Hi, is it possible to permit Cayenne Docs to be downloaded as a PDF file. Some users would like to read the information available online offscreen. Rgds
Hi there,
If you Print as PDF it should give you a solid PDF file of the docs.
Hi, tried but it is not working. Pl see pdf file. It is not printing all the documents and no link to videos or resources. Not able to upload pdf file so have uploaded screenshot. Any advice would be most appreciated. thks.
you have to open each topic in the sidebar and then save as pdf file. so in total you will have 11 separate pdf.
Hi, pl see screenshot, pdf file does not format correctly.
you can give this a try http://webpagetopdf.com/
