Cayenne Ethernet, how to confirm connection on lcd
Hi all,
I’ve got my project sensors all working and parsing to Cayenne nicely. Through the serial monitor I can see the standard connection process; MAC, IP and “Connecting” until you get the “Ready” and ping response time. I can’t figure out however how to translate this library function across for use with an LCD so when deployed outside where I have no serial monitor I can get confirmation on the lcd before proceeding.
I have had an attempt but it always indicates failure even though the connection runs through serial without difficulty.
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
#include <DHT.h>
#include <DHT_U.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x26, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
#include <CayenneEthernet.h>
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { yourinfo};
IPAddress arduino_ip(yourinfo);
IPAddress gateway_ip(yourinfo);
IPAddress subnet_mask(255, 255, 255, 0);
EthernetClient client;
// Virtual Pin & Config of the DS18B20
#define VIRTUAL_PIN1 V1
#define VIRTUAL_PIN2 V2
#define VIRTUAL_PIN3 V5
#define VIRTUAL_PIN4 V6
const int tmpPin = 2;
float cap1;
float cap2;
float cap3;
float cap4;
OneWire oneWire1(tmpPin);
DallasTemperature sensors(&oneWire1);
//Virtual Pin & Config of the BMP085
#define TEMPERATURE_PIN V3
#define BAROMETER_PIN V4
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10180);
bool bmpSensorDetected = true;
//Virtual Pin & Config for DHT11
#define DHT_HUMIDITY_PIN V7
#define DHT_TEMPERATURE_PIN V8
#define DHTPIN 4          // Pin which is connected to the DHT sensor.
#define DHTTYPE DHT11     // DHT 11
float dht11T;
float dht11H;
DHT_Unified dht(DHTPIN, DHTTYPE);
uint32_t delayMS;                   //Delay between sensor reading
//Setup the Moister sensor variables (Analogue or digital read - set pin accordingly
int moisterPin = A1;
int moisterValue = 0;
#define MOISTER_PIN V9
char token[] = "yourinfo";
int runOnce = 0; //State variable for tracking the first time device runs
  Serial.begin(115200);   //Ensure you set the correct Baud rate if you intend to add/use serial writes for debugging
  Cayenne.begin(token);
  sensors.begin();
  dht.begin();
  // Print temperature sensor details.
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  // Print humidity sensor details.
  dht.humidity().getSensor(&sensor);
  // Set delay between sensor readings based on sensor details.
  delayMS = sensor.min_delay / 1000;
  if (!bmp.begin())
    CAYENNE_LOG("No BMP sensor detected");
    bmpSensorDetected = false;
  if (runOnce == 0) {
    delay(5000);
    lcdInitialDisplay ();
    runOnce = 1;
void DHTSensorT () {
  // Get temperature event from the DHT11 humidy/Temp Sensor
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  dht11T = (event.temperature);
  Serial.print("Temperature:: ");
  Serial.print(dht11T);
  Serial.println("'C");
void DHTSensorH () {
  // Get humidity event from the DHT11 humidy/Temp Sensor
  dht.humidity().getEvent(&event);
  dht11H = (event.relative_humidity);
  Serial.print("Humidity: ");
  Serial.print(dht11H);
  Serial.println("%");
  // Delay between measurements.
  //delay(delayMS);
void moisterSensor() {
  moisterValue = analogRead(moisterPin);
  //sensorValue = map(sensorValue,160,1023,0,1000);
  Serial.print("Moister: ");
  Serial.print(moisterValue);
// This function is called when the Cayenne widget requests data for DHT11 Humidity
CAYENNE_OUT(DHT_HUMIDITY_PIN)
  Cayenne.virtualWrite(DHT_HUMIDITY_PIN, (dht11H), HUMIDITY, PERCENT);
  DHTSensorH();
// This function is called when the Cayenne widget requests data for  DHT11 Temperature
CAYENNE_OUT(DHT_TEMPERATURE_PIN)
  Cayenne.virtualWrite(DHT_TEMPERATURE_PIN, (dht11T), TEMPERATURE, CELSIUS);
  DHTSensorT();
// START - These functions are called when the Cayenne widget requests data for the DS18B20 Temp Sensors (x4)
CAYENNE_OUT(VIRTUAL_PIN1)
  cap1 = sensors.getTempCByIndex(0);
  Cayenne.celsiusWrite(VIRTUAL_PIN1, cap1);
CAYENNE_OUT(VIRTUAL_PIN2)
  cap2 = sensors.getTempCByIndex(1);
  Cayenne.celsiusWrite(VIRTUAL_PIN2, cap2);
CAYENNE_OUT(VIRTUAL_PIN3)
  cap3 = sensors.getTempCByIndex(2);
  Cayenne.celsiusWrite(VIRTUAL_PIN3, cap3);
CAYENNE_OUT(VIRTUAL_PIN4)
  cap4 = sensors.getTempCByIndex(3);
  Cayenne.celsiusWrite(VIRTUAL_PIN4, cap4);
// START - This function is called when the Cayenne widget requests data for the BMP085 Barometer/Temp Sensor Virtual Pin.
CAYENNE_OUT(BAROMETER_PIN)
  if (bmpSensorDetected)
    // Send the command to get data.
    bmp.getEvent(&event);
    if (event.pressure)
      // Send the value to Cayenne in hectopascals.
      Cayenne.hectoPascalWrite(BAROMETER_PIN, event.pressure);
  else
// This function is called when the Cayenne widget requests data for the temperature's Virtual Pin on BMP085 Sensor
CAYENNE_OUT(TEMPERATURE_PIN)
    float temperature;
    bmp.getTemperature(&temperature);
    // Send the value to Cayenne in Celsius.
    Cayenne.celsiusWrite(TEMPERATURE_PIN, temperature);
  else
void lcdInitialDisplay () {
  lcd.init();                      // initialize the lcd
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Pond M8 Version 1");
  lcd.setCursor(0, 2);
  lcd.print("IP: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    lcd.print(Ethernet.localIP()[thisByte], DEC);
    lcd.print(".");
  lcd.setCursor(0, 3);
  lcd.print("Status: ");
  if (client.available()) {
    lcd.setCursor(8, 3);
    lcd.print("Connected");
  } else {
    lcd.print("Failed");
Hi Dave,
Which Arduino device/Ethernet Shield are you trying to connect to Cayenne here?
Mega & W5100.
As I said, the Cayenne side is working fine but I’m being a bit thick trying to achieve the connection status response for use with lcd, error checking etc.
With the same code I’m also experiencing a strange conflict between Arduino, IFTTT and Wemo. I have my outside lights on a Wemo Smart switch, connected to IFTTT to activate at sunset. I also have Hue on IFTTT. Both run fine until i connect the Arduino, running the above code, and then the Wemo IFTTT activation doesn’t happen, yet the Hue does.
A problem for another thread though i suppose
Here is some info from another thread where they are running code based on connected/disconnected status. Does this help?
It’s working a treat and many many thanks for the pointer.
