Cayenne Is not Installing On Pi. The host is not rechable
Web And Android
What OS? (Jessie)
Jessie
What Model Pi?
Pi 3
It is not being downloaded . Issue seems to be with this file .
http://updates.mydevices.com/raspberry/myDevices-1.0.tar.gz
Hi @mustajabhannan,
We’ve created a post to trouble shoot potential issues. Would you mind taking a look and seeing if it applies? Keep us updated with what you find.
Hey , I guess You did’nt read the issue. xD. Well thats not the issue. Right now , Cayenne is not being installed on Pi. Actually what I found the problem is that , a file at http://updates.mydevices.com/raspberry/myDevices-1.0.tar.gz this location is not being found. I think the problem is there itself.
Thank You .
Sorry about that. Is there an error? Can you post what the terminal is showing?
Is the page which I mentioned above is working at your end ??
It just stops and hangs saying Getting Headers 0% .
Thanks .
PS: Thanks For Quick Reply. :slight_smile:
Yes, the page should be working. I’ve also just confirmed by doing a new install too, no issues.
Try doing sudo apt-get upgrade and sudo apt-get update on the Pi 3. If you have a early version of Jessie on the Pi 3 then I find that this helps.
Keep us updated,
Well , Thats weird. I’ll try again.
Sorry to say , But it is’int installing . ! :frowning:
Here is the screenshot. @bestes
Another Screenshot. The latest one.
Is there any alternative method . ?
@bestes
A couple quick thoughts-
Are you using Jessie full version, or Jessie Lite?
Could you post the output from the following command on your Pi-
df -h
Thanks,
-Ian
There you go. Its Jessie Full Version.
I’m tried installing it on Pi2 As well , But it didnt work .
@Ian
Well darn.
That is very odd.
Were these fresh OS installs? Or are there other packages running on these systems?
Ian
#14
What do u mean by fresh install ? and other packages ??
@Ian
#15
Sorry for the confusion.
By a fresh install, I mean did you just now install Jessie on the SD card or have you been using it for other things prior to installing Cayenne.
And by other packages, I mean have you installed other software on the card prior to trying to install Cayenne? Things like Webiopi have been known to interfere with Cayenne installations.
Ian
#16
Nop. I am using WiringPi , Mailing Server and Apache Server with bla bla bla. Simply I’m running LAMP.
@Ian
#17
Sounds like a busy machine! Sadly all of the installs I have done are basically stand alone Cayanne boxes. Maybe I’ll load up a Pi with lots of stuff (LAMP) and give it a try. Unfortunately I don’t have the time to do that tonight.
This is where we reach out to the group and ask- anyone had problems installing Cayenne on a LAMP box?
@mustajabhannan sorry I wasn’t more help.
Ian
#18
No Problem. Thanks For Your Help. But actually Still I would say the same. That is On my end the file
Is not being downloaded and connection times out. Please give it a try downloading this link. What happens when u visit this link ?
@Ian
#19
Downloaded onto my windows box in about 8 seconds.
Sorry.
I’m guessing with all the other stuff you have loaded onto your Pi’s, you’ve never had a problem downloading .gz files before.
Weird.
Ian
#20
Well , I think this is it. At my end this file does not get loaded. The page times out saying DNS Not FOUND.
Seems to be a network issue. Thanks Alot for your support
@Ian
