Cayenne issue on Adafruit Huzzah with luminosity sensor TSL2561
Adafruit Huzzah + TSL2561. No data displayed on Cayenne dashboard.
Log:
[xxxxx] <msg xx,xxx,xx
<vw3lum,lux=%.3f - reply form Cayenne.luxWrite?
127.00 lux - this is read actual data from sensor
Where is issue ?
Hi there @viktoras,
It would be most helpful if you could post your code, since I’m not sure what the issue is yet.
Thanks!
Device Adafruit Huzzah(ESP8266) Issue is TSL2561 data not displayed on Console.
Part of log:
<msg 20,29,17
    <vw3lum,lux=%.3f
 >msg 20,30,4
Code:
#include "CayenneDefines.h"
#include "Wire.h"
#include "Adafruit_Sensor.h"
#include "Adafruit_TSL2561_U.h"
char token[] = "";
char ssid[] = "";
char password[] = "";
#define VIRTUAL_PIN_1 V1 //PIR
#define VIRTUAL_PIN_2 V2 //Relay
#define VIRTUAL_PIN_3 V3 //LUX
const int motionSensorPin = 14;
const int relayPin = 13;
const int address = TSL2561_ADDR_FLOAT;
Adafruit_TSL2561_Unified tsl = Adafruit_TSL2561_Unified(address, 12345);
  pinMode(relayPin, OUTPUT);
  if (!tsl.begin())
    CAYENNE_LOG("No TSL2561 detected");
    while (1);
  tsl.enableAutoRange(true);
  /* Changing the integration time gives you better sensor resolution (402ms = 16-bit data) */
  tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_13MS);      /* fast but low resolution */
  // tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_101MS);  /* medium resolution and speed   */
  // tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_402MS);  /* 16-bit data but slowest conversions */
 * 220V relay
 CAYENNE_IN(VIRTUAL_PIN_2)
  if (currentValue == 0) {
    digitalWrite(relayPin, HIGH);
  } else {
    digitalWrite(relayPin, LOW);
 * PIR
CAYENNE_OUT(VIRTUAL_PIN_3)
  // Send the command to get luminosity.
  sensors_event_t event;
  tsl.getEvent(&event);
  if (event.light)
    // Send the value to Cayenne in lux.
    Cayenne.luxWrite(VIRTUAL_PIN_3, event.light);
  else
    /* If event.light = 0 lux the sensor is probably saturated
    and no reliable data could be generated! */
    CAYENNE_LOG("Sensor overload");
  checkSensor();
 * TSL2561
int previousState = -1;
int currentState = -1;
void checkSensor()
  if (currentMillis - previousMillis >= 250) {
    currentState = digitalRead(motionSensorPin);
      Cayenne.virtualWrite(VIRTUAL_PIN_1, currentState);
      previousState = currentState;
Hi There,
I have the exact same issue. Not sure what is happening here. Do you know of any solution.
@viktoras @soubir wanted to follow up here.
Perhaps you can reference these posts to help get the TSL2561 sensor working?
Hi @bestes,
I couldn’t get it to work on esp but got it working on a raspberry pi.
