Cayenne Librady Compile Problem [solved: update Ethernet library]
Hello
I am trying to install Cayenne on my arduino with my w5100 Ethernet Shield
The problem is that i can’t compile the code from the example
Can anybody help me?
The Error is:
Arduino: 1.6.9 (Windows 10), Board: “Arduino/Genuino Uno”
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp: In member function ‘void EthernetClass::begin(uint8_t*, IPAddress, IPAddress, IPAddress, IPAddress)’:
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:65:39: error: no matching function for call to ‘W5100Class::setIPAddress(IPAddress::&)’
W5100.setIPAddress(local_ip._address);
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:65:39: note: candidate is:
In file included from C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:1:0:
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\utility/w5100.h:392:6: note: void W5100Class::setIPAddress(uint8_t*)
void W5100Class::setIPAddress(uint8_t *_addr) {
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\utility/w5100.h:392:6: note: no known conversion for argument 1 from ‘IPAddress::’ to ‘uint8_t* {aka unsigned char*}’
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:66:38: error: no matching function for call to ‘W5100Class::setGatewayIp(IPAddress::&)’
W5100.setGatewayIp(gateway._address);
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:66:38: note: candidate is:
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\utility/w5100.h:368:6: note: void W5100Class::setGatewayIp(uint8_t*)
void W5100Class::setGatewayIp(uint8_t *_addr) {
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\utility/w5100.h:368:6: note: no known conversion for argument 1 from ‘IPAddress::’ to ‘uint8_t* {aka unsigned char*}’
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:67:38: error: no matching function for call to ‘W5100Class::setSubnetMask(IPAddress::&)’
W5100.setSubnetMask(subnet._address);
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:67:38: note: candidate is:
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\utility/w5100.h:376:6: note: void W5100Class::setSubnetMask(uint8_t*)
void W5100Class::setSubnetMask(uint8_t *_addr) {
C:\Users\Dell\Documents\Arduino\libraries\Ethernet\utility/w5100.h:376:6: note: no known conversion for argument 1 from ‘IPAddress::’ to ‘uint8_t* {aka unsigned char*}’
Multiple libraries were found for “Ethernet.h”
Used: C:\Users\Dell\Documents\Arduino\libraries\Ethernet
Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
exit status 1
Error compiling for board Arduino/Genuino Uno.
Hey @bill.lask,
Welcome to the Cayenne community! Would you mind post the code that you used?
Yes i forgot
I use this code with AuthenticationToken
Cayenne Ethernet Example
This sketch connects to the Cayenne server using an Arduino Ethernet Shield W5100
Steps:
#include <CayenneEthernet.h>
char token[] = "AuthenticationToken";
	Cayenne.begin(token);
There might be some issues with your ethernet library. Looks like you have an error with this line: W5100.setIPAddress(local_ip._address); In my library that line looks like this: W5100.setIPAddress(local_ip.raw_address());
I’m using the Ethernet Library 1.1.2. Is your ethernet library up to date?
I download the cyaenne library today :confused:
The ethernet library is inside the cayenne library correct?
It’s a separate library that is specific to the shield you are using. Although actually now that I think about it Arduino IDE might come with the Ethernet library already installed. Anyway, you can check if it’s installed, see image below:
You are correct finnaly it works
thanksss
Great to hear!
amigos me pueden ayudar tengo estos errores al cargar un ejemplo:
