Cayenne MQTT-C on Dragonboard 410c
I have used Cayenne for the Raspberry Pi once before, (Simple blinky app) but I am interested in using the API to use on a Dragonboard 410c.
The platforms are very similar, except that the Dragonboard isn’t widely used. The device currently has Linux Linaro installed. (I think Raspbian works too, but I’m not sure about all of the compatibility)
Before I dive down into it, has anyone successfully used the Dragonboard 410c with Cayenne? Any tips?
It looks like it should run fine on the Linux platform, and I’ll try out the examples from GitHub.
Edit: Found this Instructable via Google. http://www.instructables.com/id/DragonBoard410c-MQTT-Send-Data-to-Cayenne/ I’ll try this first.
Yep, I was going to suggest that you can always use MQTT, but you seem to have found it. Let us know how it goes!
Do you know if the iPhone app is usable with the Bring-Your-Own-Thing devices?
Unfortunately no not yet, but it in on the road map to be released.
