Cayenne MQTT support for ENC28J60 and nano?
I know my hardware works to show a local LAN web page: Arduino Nano
and ENC28J60 Nano Ethernet shield. Saw an “IT WORKS” page for the
arduino nano using the old (pre-MQTT) sketch with only a token, not user
and password. Problem I am having is in the suggested sketch, there is
support for 5100 Ethernet shield, etc but not for the ENC28J60.
Will there be any support for this little shield? Is there a way I can modify
say a 5100 sketch and make this work?
This was all discussed pre-MQTT Arduino requirements but I have not
seen a solution for the new MQTT interface.
Thoughts? Ideas?
@kreggly can help you with this.
I don’t have one, and I don’t see a UIP MQTT header in the new Cayenne MQTT library.
It has got to be possible, just someone needs to look into what is going on in BlynkSimpleUIPEthernet and create the same for MQTT.
This basic sketch should work for the ENC28J60 but it’s just a bit too big for a Nano or a Uno. The UIP library is a pig like most of the Wifi shields. Compiles fine for the Mega.
 * For this example you need UIPEthernet library:
 *   https://github.com/ntruchsess/arduino_uip
 * Typical wiring would be:
 *  VCC -- 5V
 *  GND -- GND
 *  CS  -- D10
 *  SI  -- D11
 *  SCK -- D13
 *  SO  -- D12
 *  INT -- D2
#include <UIPEthernet.h>
#include <CayenneMQTTEthernetClient.h>
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
