Cayenne noob needs help with NodeMCU code
I’m looking to replace an ageing IO-204 device from IOBridge as IOS11 no longer supports the app. It is being used to monitor the status of two doors (digital 1/0) and control two relays; each door.
I’m no code guy as hardware is my speciality. I’m very familiar with the ESP8266 boards and flashing them with Arduino, ESPEasy, Tasmota etc.
When it comes to writing code though, this 53yr old brain struggles!
Could anyone share some code to allow me to control two digital pins with a 1s pulse on the NodeMCU and read the status of two other pins so I can configure the dashboard to show whether the door is opened or closed. As far as hooking it up, that part I’m very comfortable with. The key criteria is that the output pulses for 1s on then off when activated and that the outputs don’t pulse when the NodeMCU is rebooted (opening or closing the door).
I’ve flashed the demo ESP8266 code to my NodeMCU and can see it in the Cayenne dashboard but merging code from multiple blog posts (1 and 2) I’ve read is a bit beyond my capabilities.
Any assistance would be appreciated.
Happy to add the project to my YouTube and Blog channels on completion.
welcome to cayenne community sir.
add a custom button widget with channel 1 and add this code.
  CAYENNE_IN(1)
  int x = getValue.asInt();
  if ( x == 1)
  digitalWrite(4,  HIGH);
   delay(1000);
   digitalWrite(4,low);
using below code it will add a two state widget to your cayenne dashboard:
if (millis() - lastMillis1 > 10000)
    lastMillis1 = millis();
   int y = digitalRead(5);
   Cayenne.virtualWrite(2, y, "digital_sensor", "d");
@shramiksalgaonkar Thank you so much for your prompt reply, much appreciated. Sorry, code is not my friend :frowning:
Where would I insert your suggestion into my sample code?
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
unsigned long lastMillis = 0;
		lastMillis = millis();
		//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
#include &lt;CayenneMQTTESP8266.h&gt;
   CAYENNE_IN(1)
  if ( x == 1)
   delay(1000);
Thank you! I’ll give that a try when I get back from holidays.
Sorry, moved house and been off-grid buried in boxes for a while. Tried compiling for my NodeMCU this evening but get the following error using the above code.
exit status 1
'lastMillis1' was not declared in this scope
I suck at this. What does that mean?
sorry my mistake.
unsigned long lastMillis1 = 0;
   CAYENNE_IN(1)
  if ( x == 1)
   delay(1000);
@shramiksalgaonkar Thanks for the continued assistance, much appreciated. Looks like one last error.
   delay(1000);
"exit status 1
'low' was not declared in this scope"
Change low to LOW
