Cayenne not publishing received data
So I added code into my program and now all of the sudden even tho it is showing that it is being received by Cayenne no sensor readings on the dashboard are all 0’s
can you post the code.
thank you I figured it out though it was something wrong with the value displays on the dashboard. When I created new ones without values assigned for them like Fahrenheit, hectopascals, and lux the values showed up again instead of just staying at 0 like it was before on the dashboard even tho cayenne was receiving the values
