Have you notice about Omega Onion2? We can use a library to install Cayenne on the board.
The device is this:
https://onion.io
Yes I saw the Onion Omega! I think @laurencehr was going to try to get Omega working with Cayenne using MQTT.
I will give prize if one of you @0lab @laurencehr can get the Onion online and working with Cayenneâs MQTT libs
Yep, recently I made a Getting Started (in spanish) for the Onion Omega 2
this weekend I will think to work in unify my nodejs library and official cayenne library, for try to run that in onion omega, I have to check compatibilities, because for example in the BBG I had some problems with mraa library version 2 (I had to use v1).
Aditionally, I can use the same library for connect wit and cayenne (someone ask me for help in this).
I can try
