Cayenne on Raspberry
Hi to all!
I’m running cayenne in my raspberry pi3.
I have the needed to use cayenne dashboard in order to:
  1. select a variable value
  2. launch a python script (on the raspberry) passing to it the variable value above
This isn’t quite ready yet with the regular Cayenne agent but triggers with scripts as the action are on the road map. When you say select a variable value, do you mean enter something on the dashboard? If so then that is not currently possible. If not you can use the MQTT API http://mydevices.com/cayenne/docs/#bring-your-own-thing-api
