Hello,has anyone made a Sous - vide cooker with Cayenne a DS18B20 and a relay or SSR? seems like it would work any thoughts?
there are lot examples in the community for DS1820 and relay. have a look at them and it will help you build a Sous - vide cooker
I would love to see you do this! Seems like it should be possible.
~benny
Check out Adafruitâs âSous-vide controller powered by Arduino - The SousViduino!â at What is Sous Vide? | Sous-vide controller powered by Arduino - The SousViduino! | Adafruit Learning System for some ideas.
While a fun project and good learning experience, it just didnât give the best results expected for sous vide. I eventually went with a precision cooker. Both Anova Culinary and Chef Steps Joule are good choices with lots of positive reviews.
Bob aka âMaxâ
Ok,thanks. would Cayenne allow you to use triggers from a Ds18B20 to Trigger a SSR on and off from readings in 140 to 170 degrees F range? I tried last night but was unable to get them to trigger I wasânt sure if it was a trigger problem or if controlling something at that temp was allowed?
thanks
