About This Project
This is a project thats allows a Sywon soldering iron to be controlled by Cayenne for simple on and off operation along with a timer for auto off. I have it setup so that you can still use the manual on/off switch on the unit in addition to Cayenne so if no internet, no issue. It was a little tight getting all the components into the housing but luckily there was enough space to do so without cramming it in there. I really like the timer/auto off feature. No worrying if it was left on by mistake because the adjustable timer will shut it off after the time period expires. I still try to unplug it when i’m not using it just to be safe.
What’s Connected
It uses the Sywon K601 soldering iron from amazon (https://www.amazon.com/Sywon-Soldering-Switch-Temperature-Adjustable/dp/B01N4571Q6), a ESP01(ESP8285) for connectivity, a 3.3v power supply, and a mechanical relay. It still makes use of the built in fuse for safe operation.
Dashboard Screenshots
Photos of the Project
Schematics to follow…
