Cayenne triggers are not working
  • Device & model you are using (Ex: Pi 3 Model B)
  • What dashboard are you using? (Android)
  • I have set a simple trigger for an Led indicator and buzzer. But it won’t work. If I operate the digital outputs individually they do operate but not when set as a trigger.
@embedlyAKB welcome to the cayenne community.
there is a bug with trigger and will be fixed soon.
When is it finish?
When to finish?
cant give you a ETA but should be done by next month.
Im waiting :blush:
