Hi All,
Currently we can send ‘pressure’ data via CayenneLPP.
But, if we use Lora(wan) and only transmit this a few times a day, the receiving party is unable to use this value for calculating a (accurate) forecast.
Internally in the node, this can of course be calculated!
A pressure value without a forecast is of not much use…
My idea/feature request is to add a way to specify the forecast.
It would be best if we can add it together with the pressure (like with GPS we have 4 values)
If that ain’t possible, a new data type for the forecast (a 1 byte value)
like
unknown = 0
some_clouds
cloudy
sunny
rain
heavy_rain
snow
unstable
stable
The weather forecast is calculated by the movement of baro meter (values going up/down)
http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
Of course, extending the current pressure type with a forecast would be best.
Looking at the current CayenneLPP implementation, there is no way to signal a version number. Be could use a special type (255) for this (Data1 Type)
