Change the IP of the device from dashboard
Good day. I am wondering if this is possible since it cost a lot of hastle having to set my Pi’s static IP from home then change it again when at the office. Because if we can change the device’s IP address from dashboard, I’ll add two device. One for home and the other for the office. Thanks.
The IP shouldn’t matter, the agent that gets installed is what identifies your Pi so it should connect wherever you are at as long as port 8181 is open.
