Cheap China BMP280 Sensor
I am posting the code to communicate with cheap china BMP280 Sensor, with address 0x76
I measure Temperature, Air Pressure and Altitude and I am impressed that the measurements are accurate! :slight_smile:
Don’t forget to install pip install cayenne-mqtt
The code is copied and modified a little bit by me. It is not mine at all, but works :slight_smile:
#coding: utf-8
import Adafruit_GPIO.I2C as I2C
import time
time.sleep(5) #Sleep to allow wireless to connect before starting MQTT
MQTT_USERNAME  = "805dbad0-a6d5-11e6-a85d-c165103f15c2"
MQTT_PASSWORD  = "0057f5f6af5b1d9d88d3b409beffd26802a16c45"
MQTT_CLIENT_ID = "3ec56700-0772-11e7-a758-6524f6642477"
client = cayenne.CayenneMQTTClient()
i2c = I2C
device=i2c.get_i2c_device(0x76) # address of BMP
# this value is necessary to calculate the correct height above sealevel
# its also included in airport wheather information ATIS named as QNH
# unit is hPa
QNH=1020
print("QNH:{:.0f}".format(QNH)+" hPA")
# power mode
# POWER_MODE=0 # sleep mode
# POWER_MODE=1 # forced mode
# POWER_MODE=2 # forced mode
POWER_MODE=3 # normal mode
# temperature resolution
# OSRS_T = 0 # skipped
# OSRS_T = 1 # 16 Bit
# OSRS_T = 2 # 17 Bit
# OSRS_T = 3 # 18 Bit
# OSRS_T = 4 # 19 Bit
OSRS_T = 5 # 20 Bit
# pressure resolution
# OSRS_P = 0 # pressure measurement skipped
# OSRS_P = 1 # 16 Bit ultra low power
# OSRS_P = 2 # 17 Bit low power
# OSRS_P = 3 # 18 Bit standard resolution
# OSRS_P = 4 # 19 Bit high resolution
OSRS_P = 5 # 20 Bit ultra high resolution
# filter settings
# FILTER = 0 #
# FILTER = 1 #
# FILTER = 2 #
# FILTER = 3 #
FILTER = 4 #
# FILTER = 5 #
# FILTER = 6 #
# FILTER = 7 #
# standby settings
# T_SB = 0 # 000 0,5ms
# T_SB = 1 # 001 62.5 ms
# T_SB = 2 # 010 125 ms
# T_SB = 3 # 011 250ms
T_SB = 4 # 100 500ms
# T_SB = 5 # 101 1000ms
# T_SB = 6 # 110 2000ms
# T_SB = 7 # 111 4000ms
CONFIG = (T_SB <<5) + (FILTER <<2) # combine bits for config
CTRL_MEAS = (OSRS_T <<5) + (OSRS_P <<2) + POWER_MODE # combine bits for ctrl_meas
# print ("CONFIG:",CONFIG)
# print ("CTRL_MEAS:",CTRL_MEAS)
BMP280_REGISTER_DIG_T1 = 0x88
BMP280_REGISTER_DIG_T2 = 0x8A
BMP280_REGISTER_DIG_T3 = 0x8C
BMP280_REGISTER_DIG_P1 = 0x8E
BMP280_REGISTER_DIG_P2 = 0x90
BMP280_REGISTER_DIG_P3 = 0x92
BMP280_REGISTER_DIG_P4 = 0x94
BMP280_REGISTER_DIG_P5 = 0x96
BMP280_REGISTER_DIG_P6 = 0x98
BMP280_REGISTER_DIG_P7 = 0x9A
BMP280_REGISTER_DIG_P8 = 0x9C
BMP280_REGISTER_DIG_P9 = 0x9E
BMP280_REGISTER_CHIPID = 0xD0
BMP280_REGISTER_VERSION = 0xD1
BMP280_REGISTER_SOFTRESET = 0xE0
BMP280_REGISTER_CONTROL = 0xF4
BMP280_REGISTER_CONFIG  = 0xF5
BMP280_REGISTER_STATUS = 0xF3
BMP280_REGISTER_TEMPDATA_MSB = 0xFA
BMP280_REGISTER_TEMPDATA_LSB = 0xFB
BMP280_REGISTER_TEMPDATA_XLSB = 0xFC
BMP280_REGISTER_PRESSDATA_MSB = 0xF7
BMP280_REGISTER_PRESSDATA_LSB = 0xF8
BMP280_REGISTER_PRESSDATA_XLSB = 0xF9
if (device.readS8(BMP280_REGISTER_CHIPID) == 0x58): # check sensor id 0x58=BMP280
	device.write8(BMP280_REGISTER_SOFTRESET,0xB6) # reset sensor
	time.sleep(0.2) # little break
	device.write8(BMP280_REGISTER_CONTROL,CTRL_MEAS) #
	device.write8(BMP280_REGISTER_CONFIG,CONFIG)  #
	time.sleep(0.2)
	# register_control = device.readU8(BMP280_REGISTER_CONTROL) # check the controll register again
	# register_config = device.readU8(BMP280_REGISTER_CONFIG)# check the controll register again
	# print("config:",register_config)
	# print("control:",register_control)
	dig_T1 = device.readU16LE(BMP280_REGISTER_DIG_T1) # read correction settings
	dig_T2 = device.readS16LE(BMP280_REGISTER_DIG_T2)
	dig_T3 = device.readS16LE(BMP280_REGISTER_DIG_T3)
	dig_P1 = device.readU16LE(BMP280_REGISTER_DIG_P1)
	dig_P2 = device.readS16LE(BMP280_REGISTER_DIG_P2)
	dig_P3 = device.readS16LE(BMP280_REGISTER_DIG_P3)
	dig_P4 = device.readS16LE(BMP280_REGISTER_DIG_P4)
	dig_P5 = device.readS16LE(BMP280_REGISTER_DIG_P5)
	dig_P6 = device.readS16LE(BMP280_REGISTER_DIG_P6)
	dig_P7 = device.readS16LE(BMP280_REGISTER_DIG_P7)
	dig_P8 = device.readS16LE(BMP280_REGISTER_DIG_P8)
	dig_P9 = device.readS16LE(BMP280_REGISTER_DIG_P9)
	#print("dig_T1:",dig_T1," dig_T2:",dig_T2," dig_T3:",dig_T3)
	#print("dig_P1:",dig_P1," dig_P2:",dig_P2," dig_P3:",dig_P3)
	#print(" dig_P4:",dig_P4," dig_P5:",dig_P5," dig_P6:",dig_P6)
	#print(" dig_P7:",dig_P7," dig_P8:",dig_P8," dig_P9:",dig_P9)
	timestamp = 0
	while True: # loop
		client.loop()
			raw_temp_msb=device.readU8(BMP280_REGISTER_TEMPDATA_MSB) # read raw temperature msb
			raw_temp_lsb=device.readU8(BMP280_REGISTER_TEMPDATA_LSB) # read raw temperature lsb
			raw_temp_xlsb=device.readU8(BMP280_REGISTER_TEMPDATA_XLSB) # read raw temperature xlsb
			raw_press_msb=device.readU8(BMP280_REGISTER_PRESSDATA_MSB) # read raw pressure msb
			raw_press_lsb=device.readU8(BMP280_REGISTER_PRESSDATA_LSB) # read raw pressure lsb
			raw_press_xlsb=device.readU8(BMP280_REGISTER_PRESSDATA_XLSB) # read raw pressure xlsb
			raw_temp=(raw_temp_msb <<12)+(raw_temp_lsb<<4)+(raw_temp_xlsb>>4) # combine 3 bytes  msb 12 bits left, lsb 4 bits left, xlsb 4 bits right
			raw_press=(raw_press_msb <<12)+(raw_press_lsb <<4)+(raw_press_xlsb >>4) # combine 3 bytes  msb 12 bits left, lsb 4 bits left, xlsb 4 bits right
			# print("raw_press_msb:",raw_press_msb," raw_press_lsb:",raw_press_xlsb," raw_press_xlsb:",raw_press_xlsb)
			# print("raw_temp_msb:",raw_temp_msb,"  raw_temp_lsb:",raw_temp_lsb," raw_temp_xlsb:",raw_temp_xlsb)
			# print("raw_press",raw_press)
			# the following values are from the calculation example in the datasheet
			# this values can be used to check the calculation formulas
			# dig_T1=27504
			# dig_T2=26435
			# dig_T3=-1000
			# dig_P1=36477
			# dig_P2=-10685
			# dig_P3=3024
			# dig_P4=2855
			# dig_P5=140
			# dig_P6=-7
			# dig_P7=15500
			# dig_P8=-14600
			# dig_P9=6000
			# t_fine=128422.2869948
			# raw_temp=519888
			# raw_press=415148
			var1=(raw_temp/16384.0-dig_T1/1024.0)*dig_T2 # formula for temperature from datasheet
			var2=(raw_temp/131072.0-dig_T1/8192.0)*(raw_temp/131072.0-dig_T1/8192.0)*dig_T3 # formula for temperature from datasheet
			temp=(var1+var2)/5120.0 # formula for temperature from datasheet
			t_fine=(var1+var2) # need for pressure calculation
			var1=t_fine/2.0-64000.0 # formula for pressure from datasheet
			var2=var1*var1*dig_P6/32768.0 # formula for pressure from datasheet
			var2=var2+var1*dig_P5*2 # formula for pressure from datasheet
			var2=var2/4.0+dig_P4*65536.0 # formula for pressure from datasheet
			var1=(dig_P3*var1*var1/524288.0+dig_P2*var1)/524288.0 # formula for pressure from datasheet
			var1=(1.0+var1/32768.0)*dig_P1 # formula for pressure from datasheet
			press=1048576.0-raw_press # formula for pressure from datasheet
			press=(press-var2/4096.0)*6250.0/var1 # formula for pressure from datasheet
			var1=dig_P9*press*press/2147483648.0 # formula for pressure from datasheet
			var2=press*dig_P8/32768.0 # formula for pressure from datasheet
			press=press+(var1+var2+dig_P7)/16.0 # formula for pressure from datasheet
			altitude= (44330.0 * (1.0 - pow(press / (QNH*100), (1.0/5.255)))) # formula for altitude from airpressure
			press = press/100 # convert to hPa
			if temp is not None:
				client.virtualWrite(1, temp, cayenne.TYPE_TEMPERATURE, cayenne.UNIT_CELSIUS)
			if press is not None:
				client.virtualWrite(2, press, cayenne.TYPE_BAROMETRIC_PRESSURE, cayenne.UNIT_HECTOPASCAL)
			if altitude is not None:
				client.virtualWrite(3, altitude, cayenne.TYPE_PROXIMITY, cayenne.UNIT_METER)
			#print("temperature:{:.2f}".format(temp)+" C  pressure:{:.2f}".format(press/100)+" hPa   altitude:{:.2f}".format(altitude)+" m")
			timestamp = time.time()
Then run the file with sudo python3 filename.py
I want to ask @bestes about this file: Cayenne-MQTT-C/CayenneTypes.h at master · myDevicesIoT/Cayenne-MQTT-C · GitHub
Can I modify the file and add more UNIT Types and DATA Types?
Thank you.
Are there any particular units/types you would like to add? Adding your own custom ones won’t work since they need to match the units/types on the server.
Hello @jburhenn I was just thinking to modify them and add new icons, but it is server-client connection and won’t work.
@bestes I still have some issues with this sensor and the platform It shows me that is offline but the data is still populating and the last data packet sent is a few seconds ago:
What about LITERS? Milliliters and some metrics about liquids?
Currently we don’t have liter, milliliter, etc. support on the server, but we are planning on adding those. I’m not sure exactly when that will be, unfortunately, so I don’t have an exact date.
Okey, thank you Sir.
