Como usar
sensor de corrente acs712
Measuring Current Using ACS712
const int analogIn = A0;
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
int RawValue= 0;
int ACSoffset = 2500;
double Voltage = 0;
double Amps = 0;
void setup(){
void loop(){
RawValue = analogRead(analogIn);
Voltage = (RawValue / 1024.0) * 5000; // Gets you mV
Amps = ((Voltage - ACSoffset) / mVperAmp);
Serial.print(“Raw Value = " ); // shows pre-scaled value
Serial.print(RawValue);
Serial.print(”\t mV = “); // shows the voltage measured
Serial.print(Voltage,3); // the ‘3’ after voltage allows you to display 3 digits after decimal point
Serial.print(”\t Amps = "); // shows the voltage measured
Serial.println(Amps,3); // the ‘3’ after voltage allows you to display 3 digits after decimal point
delay(2500);
obg pela informação mais como eu crio o gráfico se nao tem a o picão
deste sensor de corrente
How do I implement this in cayenne.
You can use Virtual Pins
yes
what would my sketch look like?
http://mydevices.com/cayenne/docs/#sketch-files-using-analog-vs-virtual-pins
where do I put my formula to convert the raw data into something more intelligible?
int RawValue= 0;
double Voltage = 0;
double Amps = 0;
void setup(){
void loop(){
delay(2500);
