Confused on how the channels work. I select a channel for a temp sensor and I can save but when I leave and come back to edit the channel is no longer set?
you need to provide more info. which device, mobile app or dashboard?
Do you have a green + on the widget? If you click it, that will add it as a permanent widget.
