Connected Beehives
About This Project
The beekeeper has to be aware of the state of his hives in different location. The Idea is to connect hives to a location controller (solar powerred) to collect by hive the management informations (Weight, humidity inside, temperature inside, noise inside, image inside) and some information related to the location (temperature outside, humidity outside, image our the neighbouring).
Data are collected to a management application to send alerts with hives references to the beekeeper via SMS or email.
What’s Connected
(1 raspberry by location, Weight & temperature/humidity sensors, web cam) as required
#triggers & Alerts
Mydevices.com is a convenient way to collect datas, triggers and alerts.
Hi Kaiser,
This seems like a very useful project for monitoring beehive populations. Especially since bees play such an important role in ecosystems. When you have some screenshots of the Cayenne dashboard, and pictures of the Pi ‘out in the field’, do you think you can also upload them here?
Seems like you are waiting for some of the new features that Cayenne will be releasing like video streaming, new devices, and the location widgets too. These are coming!
Did you plan on adding Arduino to this at all?
P.S., you will eventually be able to package this solution to other beekeepers who might also benefit from the work you are doing. Just a thought! In case you haven’t read this post… Packaging Cayenne as app to sell products
Thanks for letting us know what you are working on, it really helps us visualize the use cases that we want Cayenne to enable :slight_smile:
