Connecting Esp8266 wifi module with Arduino uno
Hi, i am using Esp8266 wifi module with Arduino uno for my project. As i am new to this platform, i don’t know how to select and use the following setup. Please help me connect the setup to the platform. Thank u.
follow the steps from here :
change the hardware serial to a software serial on your arduino uno.
What to select in “Step 1: Choose a device to start a project”.
@shramiksalgaonkar Do you have any tutorials.
where to get:
on your cayenne dashboard go to add new > devices/widget > bring your own thing. and you will get your MQTT credential.
@shramiksalgaonkar how do i connect my arduino uno?
Should i make ESP8266-01 as shield as mentioned in the examples?
What should i select here. Plz help…
@shramiksalgaonkar Having error:
C:\Users\Nebula\Documents\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:29:34: fatal error: ESP8266SerialLibrary.h: No such file or directory
** #include “ESP8266SerialLibrary.h”**
compilation terminated.
you have not installed the library. please follow the steps from the link i gave.
    1. Install the library via the Arduino IDE (Sketch->Include Library->Add .ZIP Library) from the Cayenne extras/libraries
