Connecting ESP8266 with Cayenne using MQTT - Video
This is a video we made in collaboration with Acrobotic. It’s a great getting started video for using an ESP8266 with Cayenne over MQTT communication protocol. Enjoy!
very nice video. it worked smoothly and clear
Very good!
hey i am trying to use my own mqtt broker and cayenne to work at the same time in parallel with each other. The reason being if my internet is down i would still be able to use mosquitto running on the Pi and vice versa if my Pi server is down then Cayenne would also be able to control. I made some quick adjustments and have had 90% success. It works great but only when connected to mosquitto. If it is not connected it goes into a boot error and resets any help would be appreciated. see code below nodemcu esp826612e
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include "CayenneDefines.h"
char token[] = "XXXXXX";
//EDIT THESE LINES TO MATCH YOUR SETUP
#define MQTT_SERVER "192.168.43.115"
char ssid[] = "XXXXXX";
char password[] = "XXXXXXX";
//LED on ESP8266 GPIO2
const int lightPin = 4;
char* lightTopic = "/test/light2";
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
WiFiClient wifiClient;
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
  //initialize the light as an output and set to LOW (off)
  pinMode(lightPin, OUTPUT);
  digitalWrite(lightPin, LOW);
  //start the serial line for debugging
  delay(50);
  //start wifi subsystem
  //WiFi.begin(ssid, password);
  //attempt to connect to the WIFI network and then connect to the MQTT server
  //reconnect();
  //wait a bit before starting the main loop
  delay(2000);
  //reconnect if connection is lost
  if (!client.connected() && WiFi.status() == 3) {
    reconnect();
  //maintain MQTT connection
  client.loop();
  //MUST delay to allow ESP8266 WIFI functions to run
  delay(10);
void callback(char* topic, byte* payload, unsigned int length) {
  //convert topic to string to make it easier to work with
  String topicStr = topic;
  //Print out some debugging info
  Serial.println("Callback update.");
  Serial.print("Topic: ");
  Serial.println(topicStr);
  //turn the light on if the payload is '1' and publish to the MQTT server a confirmation message
  if (payload[0] == '1') {
    digitalWrite(lightPin, HIGH);
    client.publish("/test/confirm", "Light On");
  //turn the light off if the payload is '0' and publish to the MQTT server a confirmation message
  else if (payload[0] == '0') {
    client.publish("/test/confirm", "Light Off");
void reconnect() {
  //attempt to connect to the wifi if connection is lost
  if (WiFi.status() != WL_CONNECTED) {
    //debug printing
    Serial.print("Connecting to ");
    Serial.println(ssid);
    //loop while we wait for connection
      delay(500);
      Serial.print(".");
    //print out some more debug once connected
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
  //make sure we are connected to WIFI before attemping to reconnect to MQTT
  if (WiFi.status() == WL_CONNECTED) {
    // Loop until we're reconnected to the MQTT server
    while (!client.connected()) {
      Serial.print("Attempting MQTT connection...");
      // Generate client name based on MAC address and last 8 bits of microsecond counter
      String clientName;
      clientName += "esp8266-";
      uint8_t mac[6];
      WiFi.macAddress(mac);
      clientName += macToStr(mac);
      //if connected, subscribe to the topic(s) we want to be notified about
      if (client.connect((char*) clientName.c_str())) {
        Serial.print("\tMTQQ Connected");
        client.subscribe(lightTopic);
      //otherwise print failed for debugging
      else {
        Serial.println("\tFailed.");
        abort();
//generate unique name from MAC addr
String macToStr(const uint8_t* mac) {
  String result;
  for (int i = 0; i < 6; ++i) {
    result += String(mac[i], 16);
    if (i < 5) {
      result += ':';
  return result;
i just also realised that that the original code with out including Cayenne causes a reset. I just never noticed it because the server was always available to connect to or it eventually connected like it was supposed to do.
