Connection
i can’t connect my esp board to the wifi network even though the supplies are proper and there is a proper connection with arduino. i have even downloaded esp board files and tried AT commands but still the connection is not established. someone please help.
Hi @deepakverma.cjc,
Can you let us know which board you are using and also the code you are trying to use to connect?
Thanks,
-Benny
Screenshots really help too.
Cayenne WiFi Example
This sketch connects to the Cayenne server using an Arduino WiFi shield
Steps:
  2. Set the network name and password.
  3. Compile and upload this sketch.
#include <CayenneWiFi.h>
char token[] = “zlj4q13y0h”;
char ssid[] = “NetworkSSID”;
char password[] = “NetworkPassword”;
Arduino: 1.6.12 (Windows 7), Board: “Arduino/Genuino Uno”
Sketch uses 12,854 bytes (39%) of program storage space. Maximum is 32,256 bytes.
Global variables use 460 bytes (22%) of dynamic memory, leaving 1,588 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x29
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
"Show verbose output during compilation"
option enabled in File -> Preferences.
Hi @deepakverma.cjc
Those ‘avrdude’ error messages look like a communication failure between the Arduino IDE and the Uno rather than an issue with Cayenne or your sketch code.
The first thing I’d try is replacing your IDE version with the latest (1.8.3) so you have all of the latest bugfixes on that end. You can download it here: https://www.arduino.cc/en/Main/Software
can’t it work on the on going version
i m using 1.6.12
Can you update to 1.8.3 to see if that improves things?
