Connectivity issue adding device
Hi all,
I am a beginner with this platform. I am trying to connect my first device, but when I enter the setting to generate the sketch file, I am not able to choose the DIGITAL and ANALOG connectivity. Only VIRTIAL appears in the drop menu.
Someone can help me?
ThanksCattura
Virtual connectivity is the communication channel used to transfer data between cayenne server and your device. So in your case for virtual connectivity select channel as 1 and then add the following code:
CAYENNE_IN(1)
int x = getValue.asInt();
digitalWrite (ligth_pin, x);
Hi shramiksalgaonkar,
Thanks a lot! It helps me.
Regards
