Please how can I change the frequency of the buzzer , I’m using Potentiometer
can you provide a bit more information about this.
i want to vary the frequency of the buzzer using the potiemeter
on cayenne dashboard as a slider?
hye, can anyone help me on how to stop the buzzer remotely by using widget? btw, im newbie. this is my coding.
#define VIRTUAL_CHANNEL V1
#define SENSOR_PIN 5
#define VIRTUAL_CHANNEL 1
char username[] = "";
char password[] = "";
char clientID[] = "";
int sensorValue = A5;
int mq3_analogPin = 5; // connected to the output pin of MQ3
byte red=4, green=5, yellow=6; // pins for leds
// remember 100 to 1000 ohm resistor in series with each LED
const int buzzerPin = 9;
pinMode(red,OUTPUT);
pinMode(yellow,OUTPUT);
pinMode(green,OUTPUT);
Serial.print("Alcohol value:");
// give ample warmup time for readings to stabilize
int mq3_value = analogRead(5);
float voltage = mq3_value* (5.0/1023.0);
Serial.println(mq3_value);
Serial.print("Voltage(V)");
Serial.println(voltage);
if (mq3_value<400)
Serial.print("\nPass. Safe drive!");
digitalWrite(green,HIGH);
delay(100);
digitalWrite(green,LOW);
else if(mq3_value>800)
Serial.print("\nWARNING! You can't drive.");
digitalWrite(red,HIGH);
delay(100);
digitalWrite(red,LOW);
pinMode(buzzerPin, OUTPUT); //addigning pin to Output mode</p><p>}</p><p>void loop() {
tone(buzzerPin, 50);
delay(50);
noTone(buzzerPin);
delay(100);
else
Serial.print("\nYou're still under control. But be careful!");
digitalWrite(yellow,HIGH);
delay(100);
digitalWrite(yellow,LOW);
delay(300); //Just here to slow down the output.
CAYENNE_OUT (VIRTUAL_CHANNEL)
Cayenne.virtualWrite (VIRTUAL_CHANNEL, map(analogRead(5), 0, 1023, 0, 1023));
add a button widget with channel 2.
CAYENNE_IN(2)
if (getValue.asInt() == 1) {
noTone(buzzerPin);
im sorry. but where to put the code that you gave? because it doesnt work
add after this.
where did you put?
just like you said huhuhu
#define VIRTUAL_CHANNEL V3
#define VIRTUAL_CHANNEL 3
#define VIRTUAL_CHANNEL 2
if (mq3_value<400)
delay(100);
delay(100);
delay(50);
noTone(buzzerPin);
delay(100);
else
delay(100);
Cayenne.virtualWrite (VIRTUAL_CHANNEL, map(analogRead(5), 0, 1023, 0, 100));
CAYENNE_IN(2)
noTone(buzzerPin);
why is my button do not functioning? is my coding correct? the buzzer will on when the alcohol value reach 800 but how can i stop the buzzer remotely?
change this :
to
add } after
