Couldn't set up r-pi with cayenne
    Raspberry pi 3 Model B
    Web,Android
    Hi
    This is prakash.
    I tried to connect cayenne with r-pi(OS-jessie lite) and I followed the procedure mentioned in the web. Once everything is completed r-pi got reboot automatically I received a mail stating set up cayenne completed but I was not able to redirect to my dashboard. I tried with android app as well. I got stuck in the initalling page. Kindly help me with this issue.
can you try with fresh raspbian installed.
Tried with fresh jessie lite and its working now. Not sure what is the problem earlier. Thanks anyways
