Current Sensor
Hi everyone, how to add current sensor (Ampere sensor) ACS712?FREELAB-ACS712-5A-Sensor-Arus-AC-dan-DC-Hall-Effect-Merchant--SKU08516355-2016826145812
we need more details like
  1. which device you are using.
  2. where you able to get reading from the sensor without the cayenne code. http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/the-acs712-current-sensor-with-an-arduino/
  3. was your device connected to cayenne.Adding a New Device using MQTT
then using cayenne for your project is very easy.
Im using Arduino uno with W5100, and I’d like to measure the DC current with cayenne using that sensor, can u please help me with code? Thanks
i can help you but you need to start with doing something. first, see if you can add the sensor to the Arduino and get values in the serial monitor. then add a device to cayenne. both links are provided in the previous reply.
#include <ACS712.h>
#include <NTPClient.h>
Measuring Current Using ACS712
const int analogIn = A0;
int mVperAmp = 66; // use 100 for 20A Module and 66 for 30A Module
int RawValue= 0;
int ACSoffset = 2500;
double Voltage = 0;
double Amps = 0;
//#define CAYENNE_DEBUG
#define VIRTUAL_CHANNEL_2 2
#define VIRTUAL_CHANNEL_3 3
#define VIRTUAL_CHANNEL_4 4
#define VIRTUAL_CHANNEL_5 5
#define VIRTUAL_CHANNEL_6 6
#define VIRTUAL_CHANNEL_7 7
#define VIRTUAL_CHANNEL_8 8
#define SENSOR_PIN 0
#define VIRTUAL_CHANNEL 30
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
  pinMode(VIRTUAL_CHANNEL_2, OUTPUT);
  pinMode(VIRTUAL_CHANNEL_3, OUTPUT);
  pinMode(VIRTUAL_CHANNEL_4, OUTPUT);
  pinMode(VIRTUAL_CHANNEL_5, OUTPUT);
  pinMode(VIRTUAL_CHANNEL_6, OUTPUT);
  pinMode(VIRTUAL_CHANNEL_7, OUTPUT);
  pinMode(VIRTUAL_CHANNEL_8, OUTPUT);
CAYENNE_OUT(VIRTUAL_CHANNEL)
  //Publish data every 1 seconds (1000 milliseconds). Change this value to publish at a different interval.
    lastMillis = millis();
    Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(SENSOR_PIN));
    //Cayenne.luxWrite(2, 700);
CAYENNE_IN(1) // Get current value of led 1 button
  int x = getValue.asInt();
  digitalWrite(VIRTUAL_CHANNEL_2, x);
CAYENNE_IN(2) // Get current value of led 2 button
  int x1 = getValue.asInt();
  digitalWrite(VIRTUAL_CHANNEL_3, x1);
  CAYENNE_IN(3) // Get current value of led 3 button
  int x2 = getValue.asInt();
  digitalWrite(VIRTUAL_CHANNEL_4, x2);
CAYENNE_IN(4) // Get current value of led 4 button
  int x3 = getValue.asInt();
  digitalWrite(VIRTUAL_CHANNEL_5, x3);
  CAYENNE_IN(5) // Get current value of led 5 button
  int x4 = getValue.asInt();
  digitalWrite(VIRTUAL_CHANNEL_6, x4);
  CAYENNE_IN(6) // Get current value of led 6 button
  int x5 = getValue.asInt();
  digitalWrite(VIRTUAL_CHANNEL_7, x5);
RawValue = analogRead(analogIn);
 Voltage = (RawValue / 1024.0) * 5000; // Gets you mV
 Amps = ((Voltage - ACSoffset) / mVperAmp);
 Serial.print("Raw Value = " ); // shows pre-scaled value
 Serial.print(RawValue);
 Serial.print("\t mV = "); // shows the voltage measured
 Serial.print(Voltage,3); // the '3' after voltage allows you to display 3 digits after decimal point
 Serial.print("\t Amps = "); // shows the voltage measured
 Serial.println(Amps,3); // the '3' after voltage allows you to display 3 digits after decimal point
 delay(2500);
I still can’t measure the curent :disappointed_relieved::disappointed_relieved:
follow this tutorial and see if you get current reading, http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/the-acs712-current-sensor-with-an-arduino/
