Custom device on mobile app
So, I managed to get my application working. I need to use an ultrasonic sensor to measure water level on a tank, in order to turn the pump on or off depending on level of water, and avoid burning the pump if it ran out of liquid to pump.
I also need to keep track of the water level historically, but I’m still working on it as I want to record it to the Arduino SD slot.
I’m using MQTT and “bring your own device option”. Everything works just fine, but I can’t see my device on my mobile app (android)…I can see the regular arduino boards, the raspberry, but not the custom device…
Any idea why?
For the community, here is the code:
//#define CAYENNE_DEBUG
#define trigPin 2
#define echoPin 3
char username = “”;
char password = “”;
char clientID = “”;
unsigned long lastMillis = 0;
pinMode (trigPin, OUTPUT);
pinMode (echoPin, INPUT);
pinMode (4,OUTPUT);
pinMode (5,OUTPUT);
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(2000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
Serial.print (distance);
Serial.println (“cm”);
if(millis() - lastMillis > 5000) {
lastMillis = millis();
//Cayenne.virtualWrite(0, lastMillis);
//Cayenne.luxWrite(2, 700);
Cayenne.virtualWrite(0, distance, TYPE_PROXIMITY, UNIT_CENTIMETER);
//CAYENNE_CONNECTED()
CAYENNE_IN_DEFAULT()
if (request.channel = 4)
String value;
value = (String)getValue.asString();
if (value == “1”)
digitalWrite(4,HIGH);
Serial.println(“Pump ON”);
else
digitalWrite(4,LOW);
Serial.println(“Pump OFF”);
Hi Fabio,
It’s not your sketch, it just that we haven’t launch the MQTT/‘Bring your own thing’ feature on mobile yet. Right now our mobile apps are limited to Raspberry Pi and Arduino, MQTT and LoRa are web dashboard only. We’re hard at work on bringing the mobile apps to feature parity so check back often for updates. It will surely be in the mobile release notes through the app store when we launch those features as well.
This is also my main problem right now!
I’m going 100% mqtt, but not having it show up on mobile is a pain. Please give us that :slight_smile:
